LG 27UL650 vignette
20 Jul 2020
I just received a new LG 27UL650 this morning and disappointed see quite a strong vignette, corners and edges have significant shadows, making solid colours look like gradients. The uniformity on my the current Dell U2412 monitors I use is much better.
I had high hopes for this budget option being suitable for graphic design after reading reviews. Have I been unlucky, should I try returning for a different panel? Or should I try a different monitor and spend a bit more?
Any suggestions of similar spec monitor more suited for graphic design would be appreciated.
