LG 32UL950-W and G-Sync
11 Nov 2009
Edinburgh
Following on from advice given to someone in another thread about finding a monitor then asking whether G-Sync will be supported on this with a 2080Ti?
You might want to keep an eye on this thread: https://hardforum.com/threads/vrr-freesync-nvidia-display-test-thread.1975513/
There's an embedded google spreadsheet that tracks user reported compatibility testing; sadly the monitor you're interested in isn't included yet.
Any 10-series card or newer is technically capable, it's the monitor capability that varies.
Thanks both will have a look.
Will it work out of the box or do I need to dance naked and chant before these monitors play nice or is it a simple driver installation and if so would this be automatic via the Gforce Experience program?
Latest GeForce Driver, Freesync enabled via Monitor OSD, Gsync enabled via Geforce Settings (rclick on desktop to access); that should be all you need, but a little prayer to your preferred deity probably wouldn't hurt.
Still in the research stage but thanks for your humorous response.:D
