LG 4K 32 Inch VA Monitor Smearing Issue
25 Oct 2021
london england
i got a 4K 32 Inch Monitor which ive had for two months and recently i decided to play Resident evil 7 and from what ive seen it looks really blurry when things are in motion i even noticed this when i first got the display when playing Forza Horizon 5 even with Motion blur turned off in game it looks really blurry and smearing everywhere. Im thinking about selling it but im on a tight budget. Im not sure what display i should go for which doesn't have this problem?
Somewhere around £250-300 does anyone know any Decent 4K Monitors that dont suffer with this smearing issue?
the words 4k 32inch high performance & budget are incompatible atm I'm afraid
like a lot of gamers you're wanting a FALD/micro-LED/OLED 4k HDMI 2.1 display at a desktop size and a sensible price but none exist right now
One of the downsides of VA based panels is there slow black to gray pixel response speed and this is what your seeing.
If you want something better you would need to up your budget and look for something based on an IPS panel especially at the 32" size.
99+% of VA panels have really slow dark shade transitions compared to other LCD types.
So if you're seeing it in those dark shades, it's standard VA "black smear".
While 60Hz 4K monitors can be found for really cheap, gaming capable 100+Hz models are expensive.
On your budget 1440p is the best option. Well priced 1440p are all over and look fantastic
Im currently looking around at reviews and many different monitors as we speak i might go with your suggestion and go for a 1440p High Refresh Rate IPS panel instead.
