LG G3 Android OS Battery Drain HELP
9 May 2009
Hi
Over the past 2 days the battery life on my phone has gone from normal to draining in record time, i lost 30% in a couple of hours without even touching it!
When i go into Battery Usage its Android OS thats taking it all, FB, Whatsapp ect is like 2%.
I have no idea what is causing it, how can i find out?
The phone is also getting very hot.
What version of Android is it on?
Ususally clearing the cache partition in recovery solves it but it seems the stock recovery on the LG G3 is unable to do this.
You can go to "Settings" -> "General" -> "Storage" then select "Cached data" and clear it, but I'm not sure if this is the same as clearing the parition in recovery mode.
That's the LG G3 I'm afraid - it's not got good battery life.
Completely different to what the OP is describing. The battery is just fine it's the screen that drains it all, OPs problem is the OS not the screen ;)
Good to hear it's been fixed OP :)
