- 9 Oct 2006
- Wales
8800 GTS Issues
Ok I appreciate some help on this one as I've tried almost everything.
I have just recieved 2 of these monitors (LG L194WT 1440x900) . Set them up as usual (Dual Screen), turned on pc, to my horror monitor #1 was sharp and very crisp (very nice too) and monitor #2 was very blury and had trouble reading words etc. So I swaped the dual DVI cables around on my graphics card and now monitor #2 is sharp and monitor #1 is very blury. At least I know its not the monitors that are duff. So I restared PC and now both are very blury
What ever I do nothing seems to work. I assume its a software/setting issue. I have tried latest drivers for monitors and graphics card but to result. I have tried fiddling with the DPI and resolutions and no result. I'm running XP Pro SP2.
Any ideas on this one?
*Update
ok, I have managed to get Monitor #2 sharp again by playing with the scaling options on the Nvidia control panel (from Nvidia scaling to device scaling). I try and do the same for Monitor #1 and it does nothing, doesnt even refresh the screen before it says "are these settings ok?"
I noticed that what ever monitor is blured, the signal going into it is 1280x1024 and the monitor thats sharp is 1440x900. The 8800 GTS and windows both tell me that 1440x900 are going to both monitors.
I'm starting to dought if the 8800 GTS can perform dual screen 1440x900.
*Update
