LG M2794DP 27" WIDESCREEN LCD FREEVIEW MONITOR ONLY £269.99 INC. VAT
17 Oct 2002
Stoke
Got an excellent price for you on this LG M2794D which includes a Freeview tuner, HDMI inputs and more.
LG M2794DP 27" Widescreen LCD Freeview Monitor @ £269.99 inc VAT
With the M94D TV Monitor series, LG offers a multi-purpose all-in-one display solution for a variety of PC and home entertainment uses. Users can enjoy easy and convenient access to AV devices such as a Blu-ray player, VCR, Console, Camcorder and more. No external receiver box is required. The high-performance built-in Digital TV tuner will deliver vivid digital images and with the two built-in HDMIs, digital video and audio signals can be processed without distortion.
- Screen Size: 27" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 20000:1
- Brightness: 400cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Freeview Tuner
- Inputs: 1x Analogue, 1x DVI-D, 2x HDMI, 1x Component, 2x SCART, 1x TV Aerial, 1x CI Slot & 1x Optical Out
- Dimensions: 654.0mm x 500.0mm x 210.0mm
- Weight: 9.0kg
- Warranty: 3 Years On-Site
Only £269.99 inc VAT.
ORDER NOW
That's tempting, want to upgrade from 22", will this be a good choice?
picture quality?overall quality? TV tuner - freeview?
Thanks!
The very monitor/tv i am using! :) Not much of a reviewer im afraid but im very pleased with it after upgrading from a 19" sammy widescreen. No dead pixels or anything like that viewing angles are good with a very crisp and vibrant picture, i would recommend to anyone. I use it as my gaming rig monitor also got ps3 hooked up via hdmi and BT vision box, picture is brilliant on all. Hope this helps anyone.
My brother's considering getting a good TV/PC/Xbox monitor at around this size. Probably gonna choose this, but can anyone name any other good monitors at this size/price? Cheers.
