Caporegime
- 30 Jul 2013
Sounds like it might be a good year to upgrade ![Big Grin :D :D](/styles/default/xenforo/vbSmilies/Normal/biggrin.gif)
LG Electronics has issued a press release today ahead of CES 2019, detailing the South Korean manufacturer's new 2019 OLED TVs with Alpha 9 gen 2 processor, and it appears they will have true HDMI 2.1 with high frame rate (HFR), enhanced audio return channel (eARC), variable refresh rate (VRR) and auto low latency mode (ALLM) support.
LG's 2019 OLED TVs are the 8K 88-inch Z9, and the 4K W9 wallpaper, E9 and C9.
https://www.flatpanelshd.com/news.php?subaction=showfull&id=1546474656
LG has announced that its OLED TV line-up for 2019 will comprise the C9, E9, and W9 ranges with 4K resolution as well as B9 that will come a little later in the year.
HDMI 2.1 is the headlining feature. Increased bandwidth now allows for up to 4K at 120 frames per second – also referred to as High Frame Rate (HFR) – inputs via HDMI. Last year’s models also supported HFR but only via streaming input.
This includes an upgraded black frame insertion system called ’OLED Motion Pro’ that now operates at 100/120Hz (compared to 50/60Hz last year) and with shorter black frame cycle (25% vs. 50% last year). LG says the system eliminates flicker and maintains brightness, which were FlatpanelsHD’s two main concerns with the BFI system in the 2018 LG OLED models. Other improvements include a separate ”smooth gradation” picture setting that no longer reduces resolution.
Speaking of motion, LG confirms that the 2019 OLED models will support HDMI VRR (Variable Refresh Rate), which was first implemented in Samsung TVs and Xbox One S / X last year. It is an adaptive frame rate system that matches frame rate between console and TV in real-time for smoother gaming performance with lower lag. The TVs also support HDMI ALLM (Automatic Low Latency Mode) that automatically switches to the TV’s game mode whenever you load up a game on your Xbox One console. PlayStation 4 does not support VRR and ALLM at this time.
