LG Or Samsung
Here is a photo of my LG WTQ 22"
the blue led can be turned off with software provided if it gets on your nerves, top quality screen well worth it =)
Thanks, is the stand removable, so I can use a height adjust one?
im not entirely sure about that, i had some trouble with getting it on the stand, you really have to have a strong grip to attach it onto the base unit, when it comes the base, screen and arm come all detached.
the screen has an arm on the back so it can be positioned correctly and has a spin stand so you can rotate the screen easily without lifting it.
