LG W2361V Monitor with PS3 - Quality Issues
27 Nov 2010
I bought this monitor and I have it solely to use my PS3 on, and it's set up with HDMI cable.
The thing is, when I play my games on it I notice serious jagged edges on the edges of objects, mainly ones a bit of a distance away. And also thin or small images, such as say a power cable or any lines really, flash when you move while looking at them from a bit of a distance. They just flash from their colour to white.
And this monitor has had good reviews from what I've seen, so I'm pretty bemused and a bit frustrated, because it is really noticeable and off-putting while I play.
Is this the monitor? Do I just have a dodgy one? Is there a setting that I have got set wrong? (I've put sharpness down to 0 and played with others to no avail).
Any help would be much appreciated.
Thanks.
It sounds like you have a problem with ps3. Try switching the cables. Or try with a friends tv so you can determime the problem
