I was looking at getting this monitor and discovered the 20 increase on yesterday
ok back to the info i need.
Will i be able to run the monitor on a nvidia 7900gt or an 8800gt? as I was informed about a dual dvi issue so a little confused.
What i want is to run cs with vsync on and achieve 120fps which in theory would happen.
thanks in advance
kev
ok back to the info i need. Will i be able to run the monitor on a nvidia 7900gt or an 8800gt? as I was informed about a dual dvi issue so a little confused.
thanks in advance
kev
