- 21 Apr 2020
Hi guys, first post so be kind
I have just been building in the 011 dynamic case and wasn’t sure where to put my fan controller (ek loop connect) sat looking at the back of the case I came up with a simple little mod.
I took one of the ssd holders from the front and dremel the raised bits off
fan controller mounts the same way as a ssd, then simply cable tied the ssd holder to the cable management part at the top, it looks a little bit like its floating.
hope this helps someone out
