Lian Li 2 Mesh RGB Fan set up
25 Sep 2019
since bagging myself one of these amazing Lian Li 2 Mesh RGB cases I am in process of waiting for my fans to be in stock but when they are and I can set it up is there a preferred fan set up or is it all personal preference for which fans would be in take and which would be exhaust it has
3 front fans where the mesh is
2 Top Fans
1 Rear Fan
2 PSU Chamber fans
Just want to get the maximum airflow to take advantage of such a great case
I'd probably do front intake, top and rear exhaust. I'm not sure I'm going to bother with the PSU shroud fans.
If I have time I'm building mine today.
Blowing up thats exhaust isn't it?
Not really, its pulling in cold air from the lower compartment and blowing up towards the GPU so probably considered an intake.
The PSU shroud fans will reduce GPU temps but increase CPH temps slightly looking at the Gamersnexus testing.
Great case, just completed my build in it.
have a 3600xt @4.5ghz and a gtx1080
Using a Corsair H100i pro and cpu temps idle around 40c average (fluctuates between 36 -44) under average gaming workload it sits around the 60c region ... have not seen go anywhere near 70c.
The GPU isles around 29-32 and is sitting in the low to mid 60’s.
Compared to the H510 case, my CPU is around 10-15c better off on average and my GPU around 6-7c better on average.
3 fans in the front (rgb edition), 240mm rad in the top in push through / exhaust config and one 120mm fan in the rear in exhaust.
Great build quality, lovely case for the money.
I still need set mine up going fit all 8 fan slots be cool as anything
I've just picked up this case and its absolutely stunning. Super cool too. I've gone with the 2 shroud fans just to help my GPU breathe. I'll be getting the vertical GPU bracket for it soon. It's contents / size / look ratio is fab.
I'm waiting on my fan controller to arrive before I can set mine up
