Lian Li 2000b - any better?
5 Dec 2006
Could I do better than this for the same price (or maybe a little bit more)?
I'll be installing the apex ultra + w/c system along with the BFG GTS so space is kinda handy..........
You could do with a 1000PLUSII, that can fit a 8800gts as well.
If you really need the space then go for it, 12 HD bays are a bit overkill I think :p .
I think I read somewhere that even a PC7 can fit a 8800gts but you'd have to ask around.
Agghh....
Now I'm thinking it might be o/kill.......
....ok - let me rephrase.. best case for :- budget not really an issue, for a watercooled system, 8800 GTS, with two hard drives?
if memory serves the 8800GTS doesnt even overlap the mobo edge, its only the GTX that is larger than the mobo.
thus virtually EVERY case fits the GTS if it fits an ATX mobo.
PC-7+ will fit a GTX though.
mcgriffo said:
Call me capricious, but now I'm thinking Akasa Eclipse!!!!
(last minute nerves due to impending purchase)
Recommended?
i have not got one, but loads recommended it to me
i am after the v1000plusII, but that is because i am limited to a midi tower
people say the only down side to the eclipse is the ugly plastic front, but some people dont even find this an issue
the rest of the case, they say is top notch
search and you shall find info about it
V2000B is a superb case. If you got one you wouldn't be dissapointed. other ones to look at though;
Lian Li PC-201
Lian Li G70
Silverstone TJ-09
Recommended?
Great cases, acres and acres of space inside.
