Lian li 207 Case AIO
3 Dec 2024
UK
Hi,
just planning my first build for the Lian Li 207 case build. The AIO I went for is the Cooler Master MasterLiquid 360L for my 9800X3D but I am struggling to work out due to the AIO height if this will leave me enough space for a rear 120mm exhaust fan. Does anyone have any guidance?
Cooler Master MasterLiquid 360L has a radiator 27mm and 25mm fan total 52mm
Radiator and fan installed at the top there is 70mm max clearance so you can fit a 120mm fan at the rear according to there website.
Hi,
Let me know specifically what measurement you need and I can check tomorrow for you. top panel to top rear fan mount?
