Pre-ordered tooGot my pre-order on. Haven't had a Lian Li case since the early 2000's
Any idea when the pre-orders will be in stock to be shipped?
Where can you get replacement 170mm fans?
Can we expect RGB ones appearing (or ideally ones with a subtle light)?
Been looking at replacing my H5 flow, torn between this and the Antec Flux!
Both very similar. LL has bigger fans but replacing with identical 17cm could be an issue.
USB ports on bottom left on the LL is bad for floor placement.
They have a 3 year warranty on the fans (1 year for the case).Wonder if Lian Li would sell the fans separately, doesn’t look like there are anyone who make them otherwise.
