Permabanned
- 28 Mar 2011
- Space Man INIT
Finaly gotten on with some of it. Took it to the powder coaters today, should get it back end of the week. Haven't a name for it ether.
Plan is to have it totaly silent and really minimal inside. Rad is external under the desk and is a HW Labs 560GTX (8 140mm fans). Everything but RAM is water cooled.
Mods done...
Window cut
Shortened drive bays as low as possible
Shortened motherbord tray inline with mobo
Braided front pannel cables
Braided and then plated mains cable (audiophile in me coming out)
Powdercoated matt black
Moved USB from top to the front (might run both)
Left to sort out is pass through for the water cooling hose, pump mounting and decoupling, sleaving power cables (might cheat and buy some) and to decied wether or not to add any fans.
Tools used, hack saw, angle grinder, marker pen, squzze clamp, 3mm drill bit, drill
Just a bunch of images not everything shown will update
Mods done...
Window cut
