Including direct noise escape path in front and acoustically bad HDD mounting behind that hole?I love EVERYTHING about this case
B70 doesn't have any sound proofing, if you showed that nonexisting foam to any acoustic designer he would laugh himself to death.
Also that fashionable tray using main HDD cage is neither that good acoustically or airflow wise.
The Akasa Paxmate is far too light, way too thin and has too low a density to meet any of the criteria set above... It is unlikely that applying this product could have any significant impact on the noise of any PC in any case. Anyone with the least bit of understanding of acoustic damping will come to that conclusion in a 30-second examination. Not recommended.
http://www.silentpcreview.com/AcoustiPack_delux
