Lian Li Air Case - CPU cooler recomendations
5 Jan 2005
Engerland :)
Homework not done :(
ordered a Dark Rock Pro at the same time - didn't want to go water and stay with Air. Now realise this wont fit by 5-10 mm or so - Why Lian Li did you make an AIR case but not make it fit with the 2 best air coolers on the market?!
Cant be bothered sending case back so can anybody recommend an AIO or if there is an air cooler that fits and is good enough to cool my 5900x?
Bit of a minefield with AIOs - would like to keep around 150 - not too fussed on RGB ... quietness would be preferred.
is this case (not mini)
https://www.overclockers.co.uk/lian-li-pc-o11-air-midi-tower-black-window-ca-76u-ll.html
max cpu :
  • CPU Cooling: max 155mm
Dark rock pro 4 is
Model: Dark Rock Pro 4
- Overall dimensions without mounting material (H x W x L), (mm): 162.8 x 136 x 145.7 :rolleyes:
I originally ordered the MINI - and cancelled it thinking it didn't take an ATX psu .. now wrong.... and ordered the MIDI thinking this had more room ... but CPU clearance is actually smaller than the MINI!. Doh.
none at all - appreciate it.
Nice price! - and back to Air
Think I will give this a shot although Im assuming that leaves 1mm between the glass.... depending on how LL calculate can fit in 155mm!
Regardless of air or water, remove the front and top filters.
Had the same disappointment with the air, as the looks was ok for me.
An Arctic Freezer II 360 as exhaust on the top will cool pretty much anything, while the PWM can be set between 50-70%. Don’t need to go higher, just find the balance where the noise isn’t too intrusive.
Because while Lian Li used to be all functionality and quality design, they turned ship 180 degrees around and are nowadays fashion brand.
And PC-O11 is crappy fashion design with super inefficient use of desk space and one of the widest case widths for extremely mediocre CPU cooler clearance.
Also fans have their airflow badly constricted by those horrible slot grills.
This should give some idea of how much lower airflow is with half the "fan's area" blocked:
https://www.silverstonetek.com.tw/techtalk_cont.php?tid=wh_chessis&area=usa
In good old times Lian Li had such wire grille for rear exhaust fan...
If you like RGB, Alpenfohn Dolomit Premium would have it in 154mm height.
https://www.overclockers.co.uk/alpenfohn-dolomit-premium-120mm-argb-cpu-cooler-black-hs-05w-al.html
Might be also notably better than Scythes for Ryzens.
Scythes have convex base optimized for concavish heatspreaders and centered monolithic die of Intels.
While modern Ryzens have toward convex heatspreader and chiplets spread on wide area.
And naturally two convex surfaces make good contact only in small area.
Thanks for the info guys.
Do you know what Im going to return the case and get something else. Its a nice case. Huge for my needs but at the end of the day I don't want to really compromise on coolers or power supply (that I have already got) so I'm going to look for some other case that fits what I already have.
