Lian li D600WB, thoughts??
15 May 2012
Louth, lincs
http://www.overclockers.co.uk/showproduct.php?prodid=CA-652-LL&groupid=2362&catid=187
Has anyone had any experience with this case? I'm currently with the corsair 540 which is a very good chassis but its not great for me. I would like something a bit more flexible which looking at the specs/pics the D600 looks like it could fit the bill.
I do love these cube, double sided design's as you can have a pretty side and erm..... A messy one ;)
What do you think?
I was interested in this as well, great size, black interior, massive space and being a Lian Li the quality of fit and finish will be superb. I own an A70F full tower and it is beautifully finished. However the price of the D600 is pretty steep.
never had a lian li case so i nothing about there quality, just very drawn to this. was also liking the caselabs cube cases but would probably end up spending more than i should on bits and bobs to do it justice so this would be a nice compromise.
The quality and precision of fit on LL's is impeccable. The only reason i dont use the A70F is that i dont like it's plain aluminum interior and cable management. Theese could be sorted by a spot of modding. A very nice case to build in as theres virtually no need for a screwdriver. Thumb screws for the mobo, toolless pci and 5.25 bay systems and psu clamp bracket.
Think i'm gonna speak to CS tomoz and see when they will have some in stock, need an xmas project ;) fancy another change, ie a different cpu!!
Well i hope you get a better chip next time mate. For a wc project, the D600 seems to be a very good choice. Im gonna look into modding the A70F as it's a vastly superior case to the shinobi xl im using now. Cooling in this case is woeful.
Been collecting a few batch numbers (4930k) so will start mailshotting retailers this week and see what happens. Fancy a black edition mobo too ;)
Oh, complete platform change. I can sympathise with that. Haswell is too much of a lottery due to the rubbish paste quality, never mind trying to get one from a decent batch.
Another option in that sort of size/price range could be the Phantek Enthoo Primo? Looks better than the Lian Li IMO, albeit being a little bit smaller.
The enthoo is a nice looking case but i do prefer the cube design. I like my 540 but i want more cooling, thinking of using the rads i have then sticking a 360 monsta in the drive side.
lian li quality is good i have a 70fb and it was amazing until i cut holes in it to fit rads :D. Was looking at this as a replacement but think i will just go corsair 900d instead
Think if i were spending £300+ i'd be looking in the caselabs direction.
Same here,with the new delivery prices from caselabs it makes it even more viable option to get one shipped,cost me £100 to get my sth10 shipped :(
:eek: wow, had a quote early on in the year and it was no where near that, how much import duty did you pay??
I think the d600wb is better designed for water then the 540, the only thing I don't like is where the psu sits, all that room it could be hidden around the back. That said you will get two triple and one dual rad in there and still have all the 3.5/5.25 bays on the hidden side in tact. Overall a nice case imo.
That's exactly what I thought regarding the psu but my plat won't look to bad, still looking at layout plans, I could get the psu in the back and put a 240 monsta above then where the psu space is put another 240 monsta there.
Was mainly looking at 360x30mm front, 240x45mm top and 420x80mm right/rear, that should be enough to cool 2x780 and a 4930
would have liked to of used my white AX's but not sure if it will fit, need the case or more info.
Won't be needing any of the drive bays so more options there.
Hmmmm decisions........
Whatever I do this has got to last this time before the mrs starts divorce proceedings :D
