Lian Li Evo RGB
21 Mar 2023
Hertfordshire
Looking to use this in my new build this year as I think it looks very nice and aesthetically pleasing.
Has anyone here used this case for any of their builds? If so, how is it and are there any cons you dont really hear about in reviews?
I have a couple of HDD's that I plan on using as extra drives and wondering if there are spots where it can slot it nicely.
Also feel free to post any pictures of your builds using this case!
Easy enough to build in, quality can be bit lacking at times for the cost. Doesn't feel the most sturdy of fish tank cases and doesn't always have a nice edge where the glass meet leaving a gap.
What do you mean why it doesnt always have a nice edge? Does the quality from unit to unit?
Thats for the input that is helpful
Phanteks cases have very flush glass where they meet, my Lian Li doesn't so there is a small gap between the side / front glass panels.
there is a dedicated HDD cage on rear of case, two big openenings one is for PSU other is for HDD. I'm also looking at this case and it seems one of the best for hiding HDD out of the way if you need a lot of cheap storage
Can this only fit in 1 HDD or 2? Cause I have 2 HDD’s I need to use for storage
I saw that if you wanted to 2.5” SSD’s there’s plenty of space for multiple of those
up to 2 in the HDD cage, so sounds ideal. you can also have 2 instead of the side intake if you wanted but that sucks.
2 HDD and 2 SSD hidden out of sight behind mobo is pretty good
thats perfect! thank for the info
looks like this is the case im definitely going with then
