Lian Li Fan Help
7 Mar 2024
Coalville
Afternoon All,
I fear I have made a newbie mistake…
I have bought a Lian Li Galahad II 360mm AIO which comes with the 3 SL INF fans installed. I have also purchased a single 120mm Uni Fan TL LCD to mount on the rear of the case as exhaust.
The problem I have is the single LCD fan won’t plug into the fan controller that came with the AIO.
Can somebody point me in the right direction of what I need to do to resolve?
Do I need to have 2 seperate fan controllers or just replace the one that came with the AIO?
How many headers does your motherboard have? Do you control the fans via motherboard? If you do and have enough compatible headers, I'd just plug it into the motherboard.
The fan has a proprietary header which is not compatible with your current Lian Li fan controller, you need the LCD variant which is available for preorder on ocuk.
