Lian Li front panel plastic clips
20 Jun 2005
Hi,
I have a problem where by the female plastic clips holding the front panel of my Lian Li PC70 case have broken and no longer allow the front panel to clip on to the case.
I have searched and searched for a company stocking a replacement but cant find anyone anywhere. So here I am posting on the forum of the company I purchased it from over 5 years ago - OCUK.
Anyone got any ideas for suppliers? Or any ideas for a bodge repair that will replace the need for the original clips?
Iain
I know of a place which sells them but its out of stock :( Cant link to it as its against forum rules, but they aint hard to find if you just do a search on google UK for Lian Li Front Panel Plastic Clips :p
