Lian Li GA2 Trinity Performance AIO 360 - Fans
10 Jun 2003
ALSO POSTED IN WATERCOOLING
I`m currently building in a O11D Evo XL and grabbed the AIO above to mount in the tray side. The Performance comes with 3 ugly grey fans (uprated and speed controlled via a little slider switch to be used with L Connect) attached which seriously offend my eyes :( I had the idea of moving them to the other side of rad and fitting 3 sl120`s on the pump side in a push pull config, I would guess the fans will be mismatched performance wise albeit not a lot ? I wont connect the stock fans to L Connect but will connect the SL120`s , can you see issues with doing this ?
Also I`m a little concerned about airflow when I would have only 3 intake fans in the bottom and the others in back x1 , the top x3 and the side AIO x 6 are all exhaust. I was thinking if making the AIO intake to try and balance the pressure, (Steve at GN seems to think it wont really effect thermals that much) plus it would look better for my RGB fetish ? Any ideas ?
My 280mm in a O11 mini is also ray side and i have 2x sk140 DRGB fan on the inside and 2 P14's on the back side.
i also thought unmatched fans would make for problems but it turns out it doesn't and push pull of any sort just make is better. my fans never pass silent keep liquid under 40c underload and under 30c no load
I see you have Lian Li Galahad II Performance, Can you write how the cooling is doing? I am considering buying this cooler for my 13900kf
