**LIAN LI GALAHAD ALL IN ONE COOLER AND SL/AL UNI FANS AVAILABLE FOR ORDER**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi,
Lian li are best known for the amazing case designs and excellent quality components. They have now decided to take a shot at the CPU cooler market as they believe they can offer a cooler that can compete against the best.
Plenty of reviews will be released over the next couple of days but the early release reviews are out with already great results.
The Galahad AIO cooler is a closed loop All in one CPU cooler designed by Lian Li. It comes with a number features as well as great cooling capacity. The Pump has a magnetic cap so you can alter the look of your cooler with ease. The RGB lighting offers you the ability to add some extra personality to the look of the cooler or just the option to make it match you colour design. You can sync up the cooler with most of the mainboard manufacturers but it also has a controller for a more manual approach.
FEATURES:
- High Static Pressure fan (800-1900 PWM) Air flow max 69 CFM / Air Pressure Max 2.6 mmH2O
- Machine detailed Aluminium Housing
- Easy to sync with motherboard
- Triple Chamber Design Water Pump to increase heat exchange efficiency and reduce dead zone
- High end braided Tubing
- 400mm long tubing for flexibility
- Removable Aluminium cap on block to present two different look
- Multiple Lighting ARGB LEDs mode on Water-block and fan
Check out the 4 options below.
Stock arrival is roughly 17th-20th Aug.
Lian-Li GALAHAD 240mm High Performance RGB CPU Water Cooler - Black @ £109.99 inc VAT
All in one cooler from LIAN-LI, 240mm Radiator Design, Dual 120mm ARGB PWM Fans, ARGB Lighting on Waterbock, Intel and AMD Compatible, 5 Year Warranty
Only £109.99 inc VAT.
ORDER NOW
Lian-Li GALAHAD 240mm High Performance RGB CPU Water Cooler - White @ £109.99 inc VAT
ORDER NOW
Lian-Li GALAHAD 360mm High Performance RGB CPU Water Cooler - Black @ £139.99 inc VAT
All in one cooler from LIAN-LI, 360mm Radiator Design, Triple 120mm ARGB PWM Fans, ARGB Lighting on Waterbock, Intel and AMD Compatible, 5 Year Warranty
Only £139.99 inc VAT.
ORDER NOW
Lian-Li GALAHAD 360mm High Performance RGB CPU Water Cooler - White @ £139.99 inc VAT
ORDER NOW
Lian Li have now released the Uni fans as a separate purchase. The UNI fans can be daisy chained in order to avoid all the horrible looking cables. Available in black and white and variants.
The Lian Li UNI FAN SL120 features a clever and unique design, with the fans including contact pins and being connected via a simple plug-in system. Multiple fans no longer have to be connected individually, which saves a lot of time and prevents cable clutter.
Additionally a fluid dynamic ball bearings ensure smooth operation and improve durability. Since friction is reduced, the fans can run at higher speeds without greater energy consumption. The UNI SL120 fans have a maximum full speed of 1900 rpm with up to 31 dB (A) under full load. They also run quiet with 58.54 CFM airflow and 2.54 mm H2O static pressure at full speed
Each fan includes 32 digitally addressable RGB LEDs. This is operated via software and enables users to set both fan speed and illumination effects. Alternatively you can add to a triple pack which includes the manual controller.
Lian-Li UNI SL120 Addressable RGB White 120mm Fan @ £22.99 inc VAT
120mm Fan, Digital Addressable RGB lighting, Software Control, 58.54 cfm / 32 dBA Max, 1900 rpm, White in Colour, Daisy Chain Multiple Uni Fans
Only £22.99 inc VAT.
ORDER NOW
Lian-Li UNI SL120 Addressable RGB Black 120mm Fan @ £22.99 inc VAT
120mm Fan, Digital Addressable RGB lighting, Software Control, 58.54 cfm / 32 dBA Max, 1900 rpm, Black in Colour, Daisy Chain Multiple Uni Fans
ORDER NOW
Lian-Li UNI SL120 Addressable RGB White 120mm Fan Triple Pack with Controller @ £74.99 inc VAT
Triple 120mm Fans, Digital Addressable RGB lighting, Software Control, 58.54 cfm / 32 dBA Max, 1900 rpm, White in Colour, Daisy Chain Multiple Uni Fans
Only £74.99 inc VAT.
ORDER NOW
Lian-Li UNI SL120 Addressable RGB Black 120mm Fan Triple Pack with Controller @ £74.99 inc VAT
ORDER NOW
Lian-Li UNI SL140 Addressable RGB White 140mm Fan @ £24.95 inc VAT
140mm Fan, Digital Addressable RGB lighting, Software Control, 70.5CFM / 30 dBA Max, 1500 rpm, White in Colour, Daisy Chain Multiple Uni Fans
Only £24.95 inc VAT.
ORDER NOW
Lian-Li UNI SL140 Addressable RGB Black 140mm Fan @ £24.95 inc VAT
140mm Fan, Digital Addressable RGB lighting, Software Control, 70.5 cfm / 30 dBA Max, 1500 rpm, Black in Colour, Daisy Chain Multiple Uni Fans
ORDER NOW
Lian-Li UNI SL140 Addressable RGB White 140mm Fan Dual Pack with Controller @ £59.99 inc VAT
Dual 140mm Fans, Digital Addressable RGB lighting, Software Control, 70.5 cfm / 30 dBA Max, 1500 rpm, White in Colour, Daisy Chain Multiple Uni Fans
Only £59.99 inc VAT.
ORDER NOW
Lian-Li UNI SL140 Addressable RGB Black 140mm Fan Dual Pack with Controller @ £59.99 inc VAT
Dual 140mm Fans, Digital Addressable RGB lighting, Software Control, 58.54 cfm / 32 dBA Max, 1900 rpm, White in Colour, Daisy Chain Multiple Uni Fans
ORDER NOW
Lian-Li ST120 Addressable RGB 120mm Black Fan with Controller - Triple Pack @ £34.99 inc VAT
120mm Triple Fan Pack, High Static Pressure, Controller Included, Same fans as the Galahad AIO Coolers, ARGB Lighting, Black Design, 2 Year Warranty
Only £34.99 inc VAT.
ORDER NOW
Lian-Li ST120 Addressable RGB 120mm White Fan with Controller - Triple Pack @ £34.99 inc VAT
120mm Triple Fan Pack, High Static Pressure, Controller Included, Same fans as the Galahad AIO Coolers, ARGB Lighting, White Design, 2 Year Warranty
ORDER NOW
Lian-Li ARGB Device Cable Kit @ £11.99 inc VAT
Connect Multiple ARGB Lian Li devices, Multiple Cable, 2 of Each Cable, 1 Year Warranty
Only £11.99 inc VAT.
ORDER NOW
Lian-Li UNI AL120 Addressable RGB Black 120mm Fan @ £26.99 inc VAT
120mm Fan, Digital Addressable RGB lighting, Software Control, 58.54 cfm / 32 dBA Max, 1900 rpm, Black in Colour, Daisy Chain Multiple Uni Fans, 2 Year Warranty
Only £26.99 inc VAT.
ORDER NOW
Lian-Li UNI AL120 Addressable RGB White 120mm Fan @ £26.99 inc VAT
120mm Fan, Digital Addressable RGB lighting, Software Control, 58.54 cfm / 32 dBA Max, 1900 rpm, White in Colour, Daisy Chain Multiple Uni Fans, 2 Year Warranty
ORDER NOW
Lian-Li UNI AL120 Addressable RGB Black 120mm Fan Triple Pack with Controller @ £82.99 inc VAT
120mm Fan, Digital Addressable RGB lighting, Software Control, Controller Included, 58.54 cfm / 32 dBA Max, 1900 rpm, Black in Colour, Daisy Chain Multiple Uni Fans, 2 Year Warranty
Only £82.99 inc VAT.
ORDER NOW
Lian-Li UNI AL120 Addressable RGB White 120mm Fan Triple Pack with Controller @ £82.99 inc VAT
120mm Fan, Digital Addressable RGB lighting, Software Control, Controller Included, 58.54 cfm / 32 dBA Max, 1900 rpm, White in Colour, Daisy Chain Multiple Uni Fans, 2 Year Warranty
ORDER NOW
Lian-Li GALAHAD AIO SL 240mm High Performance RGB CPU Water Cooler - Black @ £139.99 inc VAT https://www.overclockers.co.uk/lian...nce-rgb-cpu-water-cooler-black-hs-00a-ll.html
All in one cooler from LIAN-LI, 240mm Radiator Design, Dual 120mm SL ARGB PWM Fans, ARGB Lighting on Waterblock, Intel and AMD Compatible, 5 Year Warranty
ORDER NOW
Lian-Li GALAHAD AIO SL 240mm High Performance RGB CPU Water Cooler - White @ £139.99 inc VAT https://www.overclockers.co.uk/lian...nce-rgb-cpu-water-cooler-white-hs-00b-ll.html
ORDER NOW
Lian-Li GALAHAD AIO SL 360mm High Performance RGB CPU Water Cooler - Black @ £169.99 inc VAT https://www.overclockers.co.uk/lian...nce-rgb-cpu-water-cooler-black-hs-00c-ll.html
All in one cooler from LIAN-LI, 360mm Radiator Design, Triple 120mm SL ARGB PWM Fans, ARGB Lighting on Waterblock, Intel and AMD Compatible, 5 Year Warranty
Only £169.99 inc VAT.
ORDER NOW
Lian-Li GALAHAD AIO SL 360mm High Performance RGB CPU Water Cooler - White @ £169.99 inc VAT https://www.overclockers.co.uk/lian...nce-rgb-cpu-water-cooler-white-hs-00d-ll.html
ORDER NOW
Looks great but I heared fans are very loud and pipes may actually interfere with some RAM
still could be a good Arctic alternative for those with smaller cases (sorry still can't believe tha size of Arctic's radiator)
Got my Uni-fans installed in my Lancool 2 Mesh today and disaster!
All plugged in, was all working. However, 2 mins after boot and first load into L-Connect, RGB went off on the uni-fans. I checked the Controller and it was burning hot along with a horrid electrical smell. I've checked all the cables on the controller and all were seated fine, however controller is now dead. I noticed afterwards that the bottom fan of 3 daisy chained was not adhering to PWM speeds and was going 1000 miles an hour. I'm wondering if that has somehow overloaded the box. Again, all fans were seated and tight and RGB working, albeit briefly. Upon examination, the fan in question had a sticky contact pin which the clip-on connects to. I've now freed it and fan is now working, but I am wondering if this somehow created a short. it may explain why these were prototype for so long. I've RMA'd it so I'll let the good folks at OCUK take a look - but a word of caution. Test the fans thoroughly before connecting to the controller!
If I can get hold of these fans in white I'll be pulling the trigger on an O11 Dynamic XL and two 360mm rads as well. Seems like there isn't going to be stock for ages though :(
Can't get these fans anywhere, I have even looked in the states to get them shipped over!! Anyone else check the website everyday to see if they are back in stock?
These fans will be my next RGB fan of choice, brilliant design, and competitive price.
Galahad 360 working well in the 011 dynamic on my overclocked 8700k. Just have to wait for the new fans to be back in stock.
