Lian Li Galahad II Trinity Performance AIO 360mm CPU Water Cooler - Black & AM5 Socket
1 Dec 2024
Hull
Looking for some help with fitting the all in one to my AM5 socket. I cant work out how it attaches. The instructions only cover AM4 and Intel. I bought it as it said it was suitable for AM5
Do the AM4 instructions not apply equally to AM5?
You could try having a look on YouTube? People often post their installation of coolers on there, as part of their builds.
I've just put in the 280mm one on my machine.
Is the block the same as this?
If it is, then mine came with two sets of the retaining bolts, they had phillips heads, and the AM5 had 4 dots beside the screw indent, the AM4 had no dots.
Not sur eif that makes sense. Let me know and I can take a pic of the manual that came with it.
Checked out youtube and found a video. Feel like a bit of a chump. Only trouble is the fans cover some of my mainboard connectors so difficult connecting up. Wrong chassis AIO combination. Building never used to be this difficult
