- 25 Oct 2005
I've just built a new computer using the OD11 XL. I tried to install the graphics card support bracket which uses risers which screw into the motherboard standoffs.
Problem I had is that the risers screw was too large and didnt fit the hole of the stand-off.
Has anyone else fitted one of these? What am I missing?
I'll probably end up getting a vertical mount anyway, but this is annoying me!
