- 8 Jan 2007
Hi all,
I currently have this case - Lian Li PC B25 Blue Ring
http://www.lian-li.com/en/dt_portfolio/blue-ring-pc-b25/
It's quite old now, but is a good quality case.
Now I only have one HDD installed, the cage blocks a lot of the flow from one of the front 120mm fans.
The HDD cage is removable & is screwed to the floor. Do you know if Lian Li do a replacement cage that is a single slot for 1 HDD - this way I can improve the flow a lot (to the GFX card).
Other than this - my other option would be to hacksaw/dremel the current cage, which I don't want to do.
Not sure if anyone knows if the cages are a standard fit in terms of where the screws are located?
edit: basically this, but a 3.5inch version:
http://www.lian-li.com/en/dt_portfolio/hd-08/
Thanks
Thanks
