- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
Lian Li is back! Bigger and better than every before.
Stock is due next week!
Lian Li PC-8NWX Aluminium Midi Tower Case - Black @ £129.98 inc VAT
PC-8NWX has special safety features such as folded edges at strategic points to prevent sharp edges hurting users. PC-8NWX have very simple and functional thermal design, intake the cold air from the front, and exhaust the hot air at the rear. To make the system silent, and at the same time, to keep it cool, PC-8NWX features a 12cm fan, to move large amounts of air, whilst being quiet still. PC-8NWX features Lian Li patented Anti-virbation HDD cage, which allow user to fit three 3.5" HDD. It is easy to use, no tools required, simply using the special thumb screw to secure the anti-vibration rubber ring to the HDD, and slide the HDD into the cage. There is one 120mm exhaust fan at the rear of the chassis, which is silent and can move a good volume of air.
Multi-media port connectors follow international specification standards, with one connector for easy installation. New USB3.0 ports, e-SATA, Audio supports HD Audio or AC97 Audio. The dual design is for better compatibility options. All I/O ports on the top cover, allow for easy access, there is also a dust-free cover to protect these connectors.
- Dimensions: (W) 210mm x (H) 450mm x (D) 490mm
- Front bezel Material: Aluminum
- Side Panel: Transparent Side Panel
- Body Material: Aluminum
- 5.25" drive bay: 4
- 3.5" drive bay: 4
- Motherboard: ATX / M-ATX
- System Fan (Front): 120mm Fan x 1
- System Fan (Top): None
- System Fan (Rear): 120mm Fan x 1
- I/O Ports: USB3.0 x 2 / HD+AC97 Audio
Only £129.98 inc VAT.
ORDER NOW
Lian Li PC-8FIR Aluminium Midi Tower Case - Red @ £203.99 inc VAT
The look of PC-8FI has a minimalism style. The front panel design is a combination of art and functionality, with the hair line brushed and anodized aluminum finish to make this the ultimate high-end chassis. The new internal layout has the motherboard on top of the power supply unit, which allows for easier access to the motherboard as well as more room above, thus larger CPU coolers can be used. The power supply unit at the bottom of the case is cooled with fresh cool air directly from the outside of the case, instead of pre-heated air from within. This will bring down the core temperatures and extend the lifespan of the PSU significantly. The PC-8FI is a Mid-tower case, which is ideal for the latest graphics cards in combination with the best thermal dynamics. All the internal installation can be done without tools, and is easily adjustable to optimize your hardware setup. Especially in the advent of adding in new graphics cards, equipped with 8 PCI slots this chassis can hold up to four graphics cards, supporting CrossfireX™ and 4-way SLI™.
The PC-8FI is equipped with large cooling fans, with low RPM, which still provide enough air flow to cool down the hardware adequately. The front two 120mm intakes red LED fan runs at 1200RPM. The rear 120mm exhaust fan just next to the CPU, it can remove the hot air out fast and silently. There are vents on the PCI slots, provids extra cooling to graphics card.
Multi-media port connectors follow international specification standards, with one connector for easy installation. New USB3.0 ports, e-SATA, Audio supports HD Audio. The dual design is for better compatibility options. All I/O ports on the top cover, allow for easy access, there is also a dust-free cover to protect these connectors.
- Dimensions: (W) 210mm x (H) 460mm x (D) 490mm
- Front bezel Material:Aluminum
- Side Panel: Aluminum
- 5.25" drive bay: 3
- 3.5" drive bay (External): 1(use one 5.25 to 3.5 converter)
- 3.5" drive bay (Internal): 6
- System Fan (Front): 120mm Red LED Fan x 2 (1200RPM)
- System Fan (Top): 140mm Fan Hole x 1 (Fan not included)
- System Fan (Rear): 120mm Red LED Fan x 1 (1200RPM)
- I/O Ports: USB3.0 x 2 / e-SATA x1 / HD Audio
Only £203.99 inc VAT.
ORDER NOW
Lian Li PC-6B Case - Black @ £83.99 inc VAT
nonl2brThe newest case from Lian Li gives masses of features for little cost! With USB 3.0 support and excellent cooling, your PC will be happy all day long in this chassis.<br>
<br>
- Dimensions: (W) 210mm x (H) 475mm x (D) 498mm <br>
- Front bezel Material: Aluminum <br>
- Side Panel: Aluminum <br>
- Body Material: Aluminum <br>
- Net Weight: 5KG <br>
- 5.25" drive bay (External): 3 <br>
- 3.5" drive bay (External): None <br>
- HDD bay: 3.5” HDD x 3 / 2.5” HDD x 2 <br>
- Expansion Slot: 8 <br>
- Motherboard: ATX / Micro-ATX / Mini-ITX <br>
- System Fan (Front): 140mm Fan x 1 <br>
- System Fan (Top): None <br>
- System Fan (Rear): 120mm Fan x 1 <br>
- I/O Ports: USB 3.0 x 1 / USB 2.0 x 1 / HD Audio <br>
- Maximum Video Card Size: 440mm<br>
<br>
<center><iframe width="425" height="349" src="
" frameborder="0" allowfullscreen></iframe></center>
Only £83.99 inc VAT.
ORDER NOW
Lian Li PC-A04B Aluminium Midi-Tower Case - Black @ £82.99 inc VAT
Small or big? The PC-A04 is a small space with big features! With room for three 120mm fans, seven 3.5" Hard Drives and even space for graphics cards up to 370mm in length. The chassis is made entirely from Aluminium and all external panels are brushed for an amazing finish. With USB3.0 and e-SATA support these case will encompass your needs for years to come.
- Dimensions: 188 x 386 x 460mm (W x H x D)
- Aluminium Material
- 2 x 5.25" Drive Bays
- 1 x 2.5" Drive Bay
- 7 x 3.5" Drive Bays
- Expansion Slots: 4
- Motherboard Compatibility: MicroATX / Mini-ITX
- Front System: 120mm Fan x 2
- Top System: 120mm Fan x 1
- I/O Ports: 1 x USB3.0 / 1 x USB2.0 / 1 x e-SATA / HD Audio
- Max GPU Size: 370mm
Only £82.99 inc VAT.
ORDER NOW
Lian Li PC-A05FNB Aluminium Midi Tower Case - Black @ £74.99 inc VAT
With its mid-tower form factor, the PC-A05FN features a 120mm intake fan - positioned at the top of the rear panel - and a 120mm exhaust fan, which finds itself located on the front panel, in front of the HDD bay. The PSU bay is also located at the front of the chassis, and for additional cooling, there's accommodation for a 140mm fan along the top panel, and venting too. As usual, Lian Li also includes two rubber-lined holes on the rear panel, allowing for flexibility with the installation of liquid cooling solutions.
The PC-A05FN provides three 3.5in and two 2.5in bays internally, plus a single 3.5in and two external 5.25in bays. Graphics cards up to 280mm in length are supported.
- Dimensions: (W) 210mm x (H) 385mm x (D) 500mm
- 5.25" drive bay (External): 2
- Expansion Slots: 8
- System Fan (Top): 140mm Fan Hole x 1 ( Fan not included )
- Maximum Video Card Size: 280mm
Only £74.99 inc VAT.
ORDER NOW
Lian Li PC-A70FB Alumiinium Full Tower Case - Black @ £160.99 inc VAT
In 2009, Lian Li have introduced the unbeatable PC-A70F for the PC gaming enthusiasts, and gaming professionals who want a high quality product with a unique flavor. The PC-A70F is manufactured in TAIWAN; handcrafted from high quality aluminum and incorporates Lian Li’s finest workmanship which has built up over more than two decade’s worth of experience.
- Material: Aluminium
- Motherboard Support:
- 5 x 5.25" Drive Bays
- 11 x 3.5" Drive Bays
- System Fan(front): 140mm Blue Fan x 2 (1000RPM)
- System Fan(Rear): 120mm Fan x 2 (1500RPM)
- I/O Ports: USB2.0 x 4, FireWire x1, e-SATA x1, Audio x 1
- Dimensions: 220mm x 590mm x 585mm ( W x H x D)
Only £160.99 inc VAT.
ORDER NOW
Lian Li PC-A71FB Alumiinium Full Tower Case - Black @ £189.98 inc VAT
The PC-A71F is manufactured in TAIWAN; handcrafted from high quality aluminum and incorporates Lian Li’s finest workmanship which has built up over more than two decade’s worth of experience. PC-A71F has hair-line brush anodized aluminum finishing with diamond cut detail. The look of PC-A71F has been designed with a door panel system; ensuring the case is virtually silent, made with an all aluminum alloy chassis, simple with minimalism stylish look.
- Motherboard Support: E-ATX / ATX / M-ATX
- System Fan(front): 140mm Fan x 2 (1000RPM)
- Dimensions: 220mm x 590mm x 615mm ( W x H x D)
Only £189.98 inc VAT.
ORDER NOW
Lian Li PC-A77FB Alumiinium Full Tower Case - Black @ £249.98 inc VAT
In 2010, Lian Li has introduced introduce the unbeatable PC-A77F for the PC gaming enthusiasts, and gaming professionals who want a high quality product with a unique flavor. The PC-A77F is manufactured in TAIWAN; handcrafted from high quality aluminum and incorporates Lian Li’s finest workmanship which has built up over more than two decade’s worth of experience.
The PC-A77F carries Lian Li’s high standard of Quality requirement. All the sharp edges have been removed for user’s safety. In addition, the external and internal surfaces have hair-line brush anodized aluminum in keeping with Lian Li’s classical style.
Lian Li redesigned the internal layout for a better thermal solution, PC-A77F uses large size cooling fans to remove the system heat , fitting two extra 140mm fans on the top faster and quieter as well as keeps the system more stable.
The look of PC-A77F is in minimalism style; users can access the front I/O ports easily. The front panel design is a combination of art and functionality, with the hair line brushed and anodized aluminum touched up this outstanding high-end chassis.
The new internal layout has the motherboard on top of the power supply unit, which allows for easier access to the motherboard as well as more room above, thus larger CPU coolers can be used. The power supply unit at the button of the case is cooled with fresh cool air directly from the outside of the case, instead of pre-heated air from within. This will bring down the core temperatures and extend the lifespan of the PSu significantly.
This chassis has superb head room space, ideal for more thermal solution choices, including watercooling. This is also supporting liquid cooling systems, with two holes at the rear of the case to allow water tubes to pass through, and the rubber cover can protect the tubes away from cutting.
Lian Li designers spent months to upgrade Lian Li’s HDD cage; the new HDD cage using special Thumb Screws with rubber suspension. no tool required, simply secure the anti-vibration rubber ring to the HDD, and slide the HDD into the cage.
The two 140mm Blue LED fans on the top cover and the 120mm fan at the rear exhaust the hot air out from the system. The fans cover the whole motherboard, and they can remove the heat fast.
- Case Type: Full Tower
- Dimensions: (W) 220mm x (H) 572mm x (D) 590mm
- Motherboard compatibility: E-ATX, ATX, M-ATX
- Motherboard cut out to allow easy change of CPU coolers
- Includeds a Smart Fan Controller with built in LCD display
- Anti-Vibration fittings built in for silencing
- Front Bezel: Aluminium
- Body Material: Aluminium
- 12 x 5.25" Drive Bays
- 9 x 3.5" Drive Bays
- 7 Expansion Slots
- Front Cooling: 120mm Blue LED Fan x 3
- Top Cooling: 140mm Blue LED Fan x 2
- Rear Cooling: 120mm Fan x 1
- Supports GFXs cards up to 365mm long
- I/O Ports: 3 x USB2.0, 1 x eSATA, HD-Audio
Only £249.98 inc VAT.
ORDER NOW
Lian Li PC-B25FB Aluminium Midi Tower Case - Black @ £132.98 inc VAT
The new PC-B25F is a mid-tower case, which is ideal for the latest graphics cards in combination with the best thermal dynamics. Easily adjustable to optimize your hardware setup. Especially in the advent of adding in new graphics cards, equipped with 8 PCI slots, can hold three or more graphics cards, supports CrossfireX™ and 3-way SLI™.
- Case Type: Mid Tower
- Dimensions: 210mm x 495mm x 490mm ( W, H, D)
- 3.5" drive bay: 6
- System Fan: 12cm Fan x 2 (1200RPM)
- System Fan: 14cm Fan x 2 (1000RPM)
- System Fan: 12cm Fan x 1 (1500RPM)
- I/O Ports: E-SATA / USB2.0 x 2 / HD+AC97 Audio
Only £132.98 inc VAT.
ORDER NOW
Lian Li PC-C50B HTPC Case - Black @ £139.99 inc VAT
PC-C50 is designed for today's user who want to build a HTPC but with the power of a full size desktop PC. Lian Li have combine modern functionality with simple lines and a classic simple theme. The external parts combine with hair line brushed anodized finishing with a metallic look to create the traditional theme expected from Lian Li. Internal structures are in a unique modular design, with everything arranged and designed to comply with end-users needs making Lian Li products user friendly as well as beautiful. There are no sharp edges inside the cases so users don’t need to worry about cutting their hands on jagged metal edges. The thermal dynamics are considered extensively and every consideration is put into the design to ensure the complete system can working at a lower temperature while still remaining relatively quiet.
- Dimensions: (W) 445mm x (H) 167mm x (D) 325mm
- Net Weight: 3.2KG
- 5.25" drive bay (External): 1
- 3.5" drive bay (Internal): 3.5-Inch HDD x3 & 2.5-Inch HDD x3
- Expansion Slot: 4
- Motherboard: Micro ATX / Mini DTX / Mini ITX
- I/O Ports: USB3.0 x 3 / HD Audio / e-SATA / MS/SD Card Reader
Only £139.99 inc VAT.
ORDER NOW
Lian Li PC-P80N Full Tower Case - Black @ £319.99 inc VAT
nonl2br
Like any manufacturer Lian Li are always trying to evolve their product range and meet the needs of consumers and the latest high end chassis to be released by them is the PC-P80N, a HPTX compatible tower with 6 pre-installed fans, support for 39cm graphics cards, 11 expansion slots and much more.
<br><br>
- Case Type: Full Tower Chassis<br>
- Front bezel Material: Aluminum<br>
- Color: Black<br>
- Side Panel: Aluminum<br>
- Body Material: Aluminum<br>
- 5.25" drive bay (External): 3<br>
- 3.5" drive bay (External): None<br>
- HDD bay: 3.5” HDD x 10 / 2.5” HDD x 2<br>
- Expansion Slot: 11<br>
- Motherboard: HPTX / EATX / ATX / Micro-ATX / Mini-ITX<br>
- System Fan (Front): 140mm Fan x 3<br>
- System Fan (Top): 140mm Fan x 2<br>
- System Fan (Rear): 120mm Fan x 1<br>
- I/O Ports: USB 3.0 x 4 / E-SATA x 1 / HD Audio<br>
- Maximum Video Card Size: 390mm<br>
- Dimensions : (W) 220mm x (H) 633mm x (D) 610mm<br><br>
Only £319.99 inc VAT.
ORDER NOW
Lian Li PC-Q06R Mini-ITX Aluminium Case / Test Bench - Red @ £56.99 inc VAT
PC-Q06 is a Mini-ITX TEST BENCH system, it supports standard Mini-ITX motherboards on the top, depending on your needs, it also supports ATX / M-ATX motherboard tray (Optional) for your system.
The clean shape of PC-Q06 with rounded edge can be fit with interior decoration easily. The hair-lined anodized aluminum exterior dress up with blue and red back-lighted power and reset buttons. The design of PC-Q06 is to be as simple as possible, the exterior of the case is also the structure of the chassis. Multi-media port connectors follow international specification standards, with one connector for easy installation. The Chassis is made of 1.5mm aluminum alloy panel, The thick and solid chassis has no vibration problem. To reduce the size of the PC-Q06, the side panel are secured with screws, it also reduce the vibration, and lower the noise level. There are vent holes at the bottom and the rear panels, allowing air to enter to cool the system down. PC-Q06 supports a single 3.5" HDD, simply un-do the screw, ideal for easy HDD installation and services. The Hard Fits at the top of the chassis underneath the external motherboard risers.
- Dimensions: (W) 205mm x (H) 210mm x (D) 250mm
- 5.25" drive bay: 1
- 3.5" drive bay: 1
- Motherboard: Mini-ITX (Option: ATX / M-ATX)
- System Fan (Front):None
- System Fan (Rear): None
- I/O Ports: USB2.0 x 2 / HD Audio
Only £56.99 inc VAT.
ORDER NOW
Lian Li PC-Q08B USB3.0 Mini-ITX Case - Black @ £82.99 inc VAT
Mini-Q PC-Q08 is made in Taiwan, with the highest quality aluminum alloy panel. The Mini-Q PC-Q08 carries the standard of Lian Li’s quality requirement, all the sharp edges had been removed to protect user’s hand. The chassis is made of 1.5mm aluminum alloy panel to ensure product’s durability and all external parts are hair-line brush anodized aluminum in keeping with Lian Li’s classical style. The clean shape of Mini-Q PC-Q08 with rounded edge can be fit with interior decoration easily. The hair-lined anodized aluminum exterior dress up with blue and red back-lighted power and reset buttons. The design of Mini-Q PC-Q08 is to be as simple as possible, the exterior of the case is also the structure of the chassis. To ensure you can put everything together easily, Lian Li design team decided to use only standard PC component inside the Mini-Q PC-O08, standard Mini-ITX motherboard, standard 5.25” optical drive, standard 3.5” hard drives, standard ATX PS/2 power supply units and standard graphics card.
- Dimensions: (W) 227mm x (H) 272mm x (D) 345mm
- Expansion Slot: 2
- Motherboard: Mini-ITX / Mini-DTX
- System Fan (Front): Black, Silver / 140mm Blue LED Fan x 1
- System Fan (Top): Black, Silver / 120mm Fan x 1
- I/O Ports: USB3.0 x 2 / HD Audio
- Maximum Video Card Size: 300mm
ORDER NOW
Lian Li PC-Q09FB Mini-ITX HTPC Chassis - Black @ £76.99 inc VAT
A Good Design is to make the life simpler, not complicate it. The Mini-Q PC-Q09F is in minimalism style, it is a combination of art and technology. The clean shape of Mini-Q PC-Q09F with rounded edge can be fit with interior decoration easily. The hair-lined anodized aluminum exterior dress up with blue and red back-lighted power and reset buttons. The design of Mini-Q PC-Q09F is to be as simple as possible, the exterior of the case is also the structure of the chassis.
- Dimensions: (W) 265mm x (H) 124mm x (D) 200mm
- 5.25" drive bay (External): 1 (Slim ODD bay)
- 3 .5" drive bay (External): None
- 3.5" drive bay (Internal): 2.5-Inch HDD space x1
- Expansion Slot: None
- System Fan (Rear):1 x 80mm fan
Only £76.99 inc VAT.
ORDER NOW
Lian Li PC-Q11B Aluminium Mini-ITX Cube Case - Black @ £76.99 inc VAT
The Mini-Q PC-Q11 carries the standard of Lian Li’s quality requirement, all the sharp edges had been removed to protect user’s hand. The chassis is made of 1.5mm aluminum alloy panel to ensure product’s durability and all external parts are hair-line brush anodized aluminum in keeping with Lian Li’s classical style. The clean shape of Mini-Q PC-Q11 with rounded edges fit with interior decoration easily. The hair-lined anodized aluminum exterior combined with blue and red back-lighted power and reset buttons. The design of Mini-Q PC-Q11 is to be as simple as possible, the exterior of the case is also the structure of the chassis.
- Case Type: Mini Tower
- Dimensions: (W) 200mm x (H) 326mm x (D) 260mm
- 3.5" drive bay (Internal): 3.5-Inch HDD x2 & 2.5-Inch HDD x2
- Expansion Slot: 2
- Motherboard: Mini ITX / Mini DTX
ORDER NOW
Lian Li PC-Q11R Aluminium Mini-ITX Cube Case - Red @ £92.99 inc VAT
- Expansion Slot: 2
Only £92.99 inc VAT.
ORDER NOW
Lian Li PC-T60 Test Bench - Black @ £64.99 inc VAT
The T60 Test Bench mounts Standard ATX & Micro-ATX motherboards, 5.25” optical drives, 3.5” and 2.5” hard drives, and a standard ATX PS/2 power-supply unit. The open design makes it easy to switch components, mod, and service. Two, standard, 5.25” optical drives mount directly above the power-supply unit. Three, 3.5” HDDs mount, using thumb-screws with rubber-suspension to prevent vibration. Aluminum mounts for two, 2.5" HDDs, directly below the M/B tray, allow user to easily install and remove them, as desired.
- ATX / Micro-ATX Test Bench
- Dimensions: (W) 351mm x (H) 400mm x (D) 330mm
- Net Weight: 1.8KG
- 5.25" drive bay: 2
- 3.5" drive bay: 3
- 2.5" drive bay: 2
- Expansion Slot: 8
- Motherboard: ATX / Micro ATX
- System Fan (Front) 120mm or 140mm Fans x 2 (optional)
- I/O Ports USB 3.0 x 2 / e-SATA x 1 / HD+AC97 Audio (optional)
- 2.5" drive bay (Internal): 2
Only £64.99 inc VAT.
ORDER NOW
Lian Li PC-U6B Special Edition Midi Tower Case - Black/Red @ £209.99 inc VAT
nonl2br
There's support for Micro-ATX or Mini-ITX mainboards, and graphics cards up to 310mm in length. Internally, there are three 3.5in and two 2.5in bays, plus a single 5.25in bay externally. The mounting system for drives is tool-less, and Lian Li adds anti-vibration thumbscrews with rubber suspension to smooth out any noise vibrations.<br><br>
Cooling duties are taken care of by dual 120mm side panel fans, which include washable air filters to keep any dust at bay. The ability to control fan speeds is also incorporated, and airflow is enhanced further, thanks to ventilation holes in the front and rear panels. These too are protected by washable air filters. If it's liquid cooling you're interested in, Lian Li adds two rubber-ringed holes for tubing to pass through, as well.<br><br>
There's USB 3.0 support, together with a complement of other connectivity options, as you'd expect. A 530mm red LED kit is also included - if you want to add some colour to the mix.<br>
<br>
- Case Type: Mid Tower Chassis <br>
- Dimensions: (W) 219mm x (H) 500mm x (D) 410mm <br>
- 5.25" drive bay (External): 1 <br>
- Expansion Slot: 4 <br>
- Motherboard: Micro-ATX / Mini-ITX <br>
- System Fan (Front): 120mm Fan x 2 <br>
- System Fan (Rear): None <br>
- I/O Ports: USB 3.0 x 2 / E-SATA x 1 / HD Audio <br>
- Maximum Video Card Size: 310mm<br>
- Package Dimensions: (W) mm x (H) mm x (D) mm<br><br><br>
Only £209.99 inc VAT.
ORDER NOW
Lian Li PC-V1020B Aluminium Midi Tower Case - Black @ £189.98 inc VAT
The huge internal space fits an ATX motherboard, and graphics cards up to 305mm long, and there are room for 7 hard drives. There are two 140mm blue LED cooling fans to cool the system down, and a lot of internal space for a liquid cooling system. It is an ideal for the gamer and pro user! Motherboard tray can easily slide out of the chassis so the user doesn't need to work in a narrow space inside the case. The fans are mounted with Lian Li’s anti-vibration fan mounting system; the rubber ring grommet absorbs the vibration, keeping the case silent. The new 5.25” bay tool-less mounting incorporates a mounting bar equipped with rubber padding. After closing the mounting bar, the rubber pad pushes and holds the 5.25” device in position to both secure and absorb vibration from the device.
- Case Type: Mid tower chassis
- Dimensions: (W) 220mm x (H) 562mm x (D) 505mm
- Net Weight
- 3.5" drive bay (Internal): 7
- Expansion Slot: 8
- System Fan (Front): 140mm blue LED fan x 2
- System Fan (Top): 140mm fan x 1
- System Fan (Rear): 120mm fan x 1
- I/O Ports: USB3.0 x 4 / e-SATA x 1 / HD Audio
ORDER NOW
Lian Li PC-V2120B Aluminium Full Tower Case - Black @ £339.98 inc VAT
The new PC-V2120 is a full-tower case, which is ideal for the latest graphic cards in combination with the best thermal dynamics. Especially in the advent of adding in new graphics cards, equipped with 11 PCI slots, which can hold three or more graphics cards, supports Crossfire and SLI.
PC-V2120 has hair-line brush anodized aluminum finishing. Huge internal space fits HPTX motherboard (have to remove one 140mm fan with HPTX M/B), and graphics card, which can up to 335mm long, and there are room for 13 hard drivers. There are 3 x 140mm and 1 x 120mm cooling fans to cool the system down, and a lot of internal space for liquid cooling system. It is an ideal for gamer and pro user!
The fans are mounted with Lian Li’s anti-vibration fan mounting system; the rubber ring grommet absorbs the vibration, keeping the case silent. The new 5.25” bay tool-less mounting incorporates a mounting bar equipped with rubber padding. After closing the mounting bar, the rubber pad pushes and holds the 5.25” device in position to both secure and absorb vibration from the device. There are noise reduction foam on the internal side of the side panel to reduce the noise level and the vibration.
There are three of 140mm fans at the front to bring the cold air into the system. The fans cover the whole motherboard, and they can remove the heat fast. There is a 120mm exhaust fan at the rear to draw the hot air out, and improve the air flow inside the chassis. On the front of the case there is a fan controller so the user can adjust the fan speed to get the best balance between silence and cooling. There are vents on the PCI slots to provide extra cooling to the graphics card.
- Dimensions: (W) 235mm x (H) 635mm x (D) 630mm
- 5.25" drive bay (External): 5
- 3.5" drive bay (Internal): 10 + 3 (Using 5.25-inch Bays x 3 )
- Motherboard: EATX / ATX / M-ATX / HPTX
- System Fan (Front): 140mm Fan x 3 & 120mm Fan x 1
- System Fan (Top): 120mm Fan Hole x 3 (Fan not included)
- Maximum Video Card Size: 360mm
- 2.5" drive bay (Internal): 2 + 2 (Using one 3.5-inch bay for 2.5-inch HDDs converter)
Only £339.98 inc VAT.
ORDER NOW
Lian Li PC-V2120X Aluminium Full Tower Case - All Black @ £367.99 inc VAT
- All Black Interior
Only £367.99 inc VAT.
ORDER NOW
Lian Li PC-V351B Aluminium Micro ATX Cube Case - Black @ £82.99 inc VAT
Lian Li designers combine modern functionality with simple lines and a classic simple theme. The external chassis combined with hair line brushed anodized finish with a metallic look to create the traditional theme expected from Lian Li. Internal structures are in a unique modular design, with everything arranged and designed to comply with end-users needs making Lian Li products user friendly as well as beautiful. There are no sharp edges inside the cases so users don’t need to worry about cutting their hands on jagged metal edges. The thermal dynamics are considered extensively and every consideration has been put into the design to ensure the complete system can work at a lower temperature while still remaining relatively quiet.
- Motherboard : Micro ATX
- Removable Motherboard Tray
- Front bezel Material : Aluminum
- Side Panel : Aluminum
- Body Material : Aluminum
- Net Weight : 3.63kg
- 5.25" drive bay (External) : 2
- 3.5" drive bay (External) : 1 ( Using 1 x 5.25)
- 3.5" drive bay (Internal) : 2
- Expansion Slot : 4
- System Fan (Front) : 120mm Ball-Bearing Fan x 1 (1000RPM)
- System Fan (Rear) : 80mm Ball-Bearing Fan x 1 (1200RPM)
- I/O Ports : USB2.0 x 2, IEEE1394 x 1, HD+AC97 Audio
- Dimensions : 279mm x 262mm x 373mm (W x H x D)
ORDER NOW
Lian Li PC-V354B Aluminium Mini-Tower Case - Black @ £126.98 inc VAT
Lian Li designers combine modern functionality with simple lines and a classic simple theme. The external parts combine with hair line brushed anodized finishing with a metallic look to create the traditional theme expected from Lian Li.
To ensure the user can put everything together easily, Lian Li designers have decided to use only standard PC components inside the PC-V354; standard Mini-ITX motherboard, standard 5.25” optical drive, standard 3.5” hard drives, standard ATX PS/2 power supply units and standard graphics cards.
Handcrafted with high quality alumium sheet materal, with one line of diamond cut, it is a simple, minimalist art work design. The PC-V354 features the Lian Li patented Anti-virbation HDD cage, which allows users to fit three 3.5" HDDs. It is easy to use, no tools are required, simply use the special thrumb screws to secure the anti-vibration rubber rings to the HDD, and slide the HDD into the cage. The PC-V354 has equipped an anti-vibration kit on the chassis, to absorb the noise. Like the EMI spring, it absorbs the vibrations, while the top cover is still easy to remove and close. There are four high quality aluminum case stands, it not only looks good, it also has rubber pads to absorb the vibrations, and prevent scratches to the equipment underneath. To reduce the vibrations from HDDs, Lian Li included HDD anti-vibration kits which use rubber rings to absorb the virbrations to reduce noise. To reduce the vibrations from fans, Lian Li included fan anti-vibration kits which use rubber rings to absorb the virbrations to reduce noise. Thermal Solution - Aluminum can remove heat four times faster than steel, therefore the PC-V354's aluminum alloy chassis can help your system to stay cooler, helping to extend your component's lifecycle. PC-V354 has equipped two 120mm intake fans, with low-RPM and high air flow, the fan is extremely silent and can bring a good volume of air from outside the case, keeping the system cool. The 140mm fan on the top cover exhausts the hot air out from the system. The front and the top fans cover the whole motherboard, and they can remove the heat fast.
- Dimensions: 245mm x 320mm x 420mm (W x H x D)
- Expansion Slot : 5
- Motherboard:Micro-ATX / Mini-ITX / Mini-DTX
- System Fan (Front): 120mm Blue LED Fan x 2
- System Fan (Top): 140mm Fan x 1
- I/O Ports: USB3.0 x 2 / HD Audio / SD Card Reader
- Maximum Video Card Size : 350mm
Only £126.98 inc VAT.
ORDER NOW
Lian Li PC-V600FB Aluminium Case - Black @ £156.98 inc VAT
This high-quality, all-aluminum computer case sports a grated front-panel design, three cooling fans (two with LED lighting), lots of build space with hot swappable capabilities, multiple USB 3.0 ports, and all the anti-vibration and tool-less features enthusiasts know are the markings of a Lian Li design. In short, another solid PC chassis from the Taiwan-based company.
Chassis Cooling
Two, great looking, 120mm LED lit fans on the front-panel pull cool air into the case while one 120mm top-panel fan expels heated air at the back of the case. Directly below the PSU mount on the bottom of the case, a vent helps to bring in cool air and is protected by a washable air filter. Venting in the PCI brackets on the back-panel further aids thermal flow.
Build Space
Two HDD cages, using thumb-screws with rubber suspension for tool-less installations, hold up to five 3.5” SATA hot swappable HDDs and two 2.5” HDDs. To increase video card space to a maximum of 370mm, one of the HDD cages can be quickly and easily removed. At the back and bottom of the case, a standard PS/2 power supply unit mounts with anti-vibration features. Side-panel removal is also tool-less on Lian Li's PC-V600F along with two 5.25” ODD mounts on the front-panel. Being a mini tower, users can choose to mount an M-ATX or Mini-ITX motherboard. At the front edge of the top-panel users have easy access to the power and reset switches along with two USB 3.0 ports, one e-SATA port, and HD Audio ports.
The all-aluminum, PC-V600F weighs in at 5kg. Its dimensions are 190mm x 390mm x 470mm (W, H, D). Design features, like cable management clips and M/B thumb screws, alongside fantastic looks, like LED lit fans and a cool looking front-panel, combine with the massive build space of the PC-V600F to make this mini tower an excellent choice for consumers looking for a high-quality, all-aluminum, top of the line computer case.
- Case Type: Mini Tower Chassis
- Dimensions: (W) 190mm x (H) 390mm x (D) 470mm
- Color: Black / Silver / Red / Black ( Internal Black )
- Net Weight: 5KG
- HDD bay: 3.5” HDD (Sata hot swap) x 5 / 2.5” HDD x 2
- System Fan (Front): 120mm LED Fan x 2
- System Fan (Top): 120mm Fan x 1
- I/O Ports: USB 3.0 x 2 / e-SATA x1 / HD Audio
- Maximum Video Card Size: 370mm
Only £156.98 inc VAT.
ORDER NOW
Lian Li PC-X2000F Aluminium Full-Tower Case - Black @ £399.98 inc VAT
The TYR PC-X2000F is the case which functionality and style converge.Open the side panel with the tool-less latch, HDD racks, 5 x140mm silent intake fans with filter, top mounted multi-media I/O ports, and the graphics card holder have been redesigned – because when it comes to your comfort, every detail counts. The PC-X2000F has two-heat zones design to have better thermal solution and tidy up internal space. The new internal layout has the motherboard on middle level, which allows for easier access to the motherboard as well as more room above, thus larger CPU coolers can be used. To install the power supply unit, just slide the power supply unit throguh the opening at the rear of the case. The fans are mounted with Lian Li’s anti-vibration fan mounting system; the rubber ring grommet absorbs the vibration, keeping the case silent. TYR PC-X2000F features Lian Li SAS hot swap HDD cage, which allow user to fit seven of 3.5" HDDs. It is easy to use, no tool required, there are aluminum handles for HDDs, allow user to install or remove HDD easier. There are three of 140mm fans at the front to bring the cold air into the system. The fans cover the whole motherboard, and they can remove the heat fast.
- Dimensions: (W) 240mm x (H) 695mm x (D) 442mm
- 3.5" drive bay (Internal): 7(SAS Hot Swap)
- Motherboard: E-ATX / ATX / Mirco-ATX
- System Fan (Rear): 140mm Fan x 2
- I/O Ports: USB3.0 x 4 / e-SATA x1 / HD Audio
Only £399.98 inc VAT.
ORDER NOW
Lian Li PC-Z60 Diamond Series Midi Tower Case - Black @ £179.99 inc VAT
nonl2br
The PC-Z70’s smaller brother is the PC-Z60. It has the same distinctive plain but stylish front fascia but internally, it is very different. The smaller size means that only 8 PCIe brackets are present at the back and the motherboard cable management holes aren’t as numerous or lined with rubber grommets. Instead of the front mounted HDD trays, the PC-Z60 welcomingly features side mounted trays and as such front intake fans that suck air from the side vents on the front aluminium panel.
<br><br>
- Case Type: Mid Tower Chassis<br>
- Front bezel Material: Aluminum + Plastic<br>
- Color: Black / Silver<br>
- HDD bay: 3.5" HDD (Sata hot swap) x 6 / 2.5” HDD x 2<br>
- Expansion Slot: 8<br>
- Motherboard: ATX / Micro-ATX / Mini-ITX<br>
- System Fan (Front): 120mm Fan x 2<br>
- System Fan (Top): 140mm Fan x 1<br>
- I/O Ports: USB 3.0 x 2 / USB 2.0 x 1 / e-SATA x 1 / HD Audio<br>
- Maximum Video Card Size: 305mm<br>
- Dimensions : (W) 210mm x (H) 472mm x (D) 480mm<br><br><br>
Only £179.99 inc VAT.
ORDER NOW
Lian Li PC-Z70 Diamond Series Full Tower Case - Black @ £249.98 inc VAT
nonl2br
One of the most popular cases in Lian Li’s vast range is the PC-A70F, renowned for its spacious interior, sleek finish and somewhat affordable pricing (compared to other Lian Li cases). Through the marriage of design between itself and the PC-B25F was born the PC-Z70. This is another case that complies to HTPX standards thanks to 11 expansion slots and a large depth. The most striking feature is its smooth plain façade with smoothly rounded edges on the side and angular corners at the top and bases. Interestingly, there are no intakes fans at the front.
<br><br>
- HDD bay: 3.5" HDD (Sata hot swap) x 9 / 2.5" HDD x 2<br>
- Motherboard: HPTX / EATX / ATX / M-ATX<br>
- System Fan (Front): 120mm Fan x 3<br>
- Dimensions : (W) 220mm x (H) 600mm x (D) 592mm<br><br>
ORDER NOW
- 3.5" drive bay: 4
ORDER NOW
ORDER NOW
<br>
<br>
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
- 7 Expansion Slots
ORDER NOW
- 3.5" drive bay: 6
ORDER NOW
- Net Weight: 3.2KG
- Expansion Slot: 4
ORDER NOW
nonl2br
<br><br>
- Color: Black<br>
ORDER NOW
- 3.5" drive bay: 1
ORDER NOW
- Expansion Slot: 2
ORDER NOW
ORDER NOW
- Expansion Slot: 2
ORDER NOW
- Expansion Slot: 2
ORDER NOW
- Net Weight: 1.8KG
- 3.5" drive bay: 3
- 2.5" drive bay: 2
- Expansion Slot: 8
ORDER NOW
nonl2br
<br>
ORDER NOW
- Net Weight
- Expansion Slot: 8
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
Chassis Cooling
Build Space
- Net Weight: 5KG
ORDER NOW
ORDER NOW
nonl2br
<br><br>
ORDER NOW
nonl2br
<br><br>
ORDER NOW
