Lian Li L-Connect 3 not showing fans
23 Apr 2007
Cardiff-ish, Wales
Hi all,
I've just built a new system with the following Lian Li fans:
Hydroshift 360R
3x Wireless TL LCD
1x Wireless TL LCD
3x Wireless TL Reverse
All fans are working, lights and LCD display fine, currently on full power.
I've connected all fans to my Lian Li PSU USB Hub. The USB Hub white connectors (far right) are connected to the motherboard.
The wireless dongle is also connected to the motherboard.
The L-Connect 3 software is version 2.04 64bit.
When I run the software it shows System Info and Settings as the options in the left panel. That's it, no fans or AIO.
Any idea what I'm doing wrong?
Just to add... I can see them in Device Manager under Universal Serial Bus Devices, so it seems like the software is the issue..?
I had no idea you could get wireless fans, pretty awesome.
It's a bit deceiving
There's still wires involved
Though in the future I can see it could
Be possible
For a company like lian li
Who makes cases and fans
You could run power to a set of pogo pins
At fan locations in the case
For fans to go on with no power wires
But probably still need a wire for controlling them
Though even that I guess may be possible
With a usb wireless receiver like mice and keyboards use
I had this problem with a Lian Li Hydroshift AIO - sadly I was on the latest version so I fixed it by ripping the supplied fans off and putting some on that didn't require their awful software. How are they still getting software SO wrong? Looking at you as well Gigabyte :D
Sorry to revive this thread after a few months but I'm having the same issue today.
Redid my rig, using a bunch of Lian LI TL wireless LCD and non LCD fans. The fans light up and spin, but no control over them. So went to download the software and it only shows *system Info* and *Settings* on the left hand side... everywhere else shows about 10 different options. I've reinstalled, move the fans, moved the power supply nothing....
Anyone any ideas?
