Anyone know why I'm getting front fan RGB working (synced with Asrock B450M Steel Legend), but fans aren't spinning?
Only one was spinning last night (top one), so I double checked everything is connected properly (front hub is as prescribed in the instructions) power from SATA, all three fans connected via the 4 pin cable to the daisy chain on the hub (3 pin won't connect to the daisy chain). And now none of the fans spin.
Absolutely flummoxed - but impressed with the thermals (even with one fan spinning and no exhaust, it's 20° cooler than current case!)
Would just like to get all three spinning.
I can't see a connection to put on a PWM header on the motherboard - someone please explain how I'm being thick...
