** LIAN-LI LANCOOL II - FEATURE RICH WITH UPGRADES GALORE **
OcUK Staff
26 Nov 2014
Stoke
Available for preorder now, we have the eagerly awaited Lian-Li Lancool II. The Lancool II builds on the successful reputation of the original Lancool model, adding a slew of new features and options into the mix. The Lancool II is available in either Black or White, and comes with E-ATX motherboard support (up to 280mm), 384mm VGA card support, 176mm CPU cooler support, 210mm PSU support, 3 pre-installed 120mm fans with space for up to 8 in total, alongside support for up to 360mm radiators at the front, and 240mm radiators at the top of the chassis. Alongside this is dual hinged tempered glass side panels, a steel and mesh front panel with a pair of addressable RGB LED strips and space for up to 7 drives, including 4 x 2.5" and 3 x 3.5"/2.5" locations.
At the back there are covers to hide messy cable management. The I/O panel consists of 2 x USB3.0, an RGB control button, Audio/Mic ports and the option to add a USB3.1 Type-C port. In fact, upgradability is a big part of the Lancool II, with the option of adding the aforementioned USB3.1 Type-C port, alongside a hot swap back panel, additional ARGB strips for adding to the shroud area and a Vertical GPU kit.
Stock is due to land on the 20th December, and any preorders on the Black model (using the bundle code below) will get a free hot swap back panel. There is limited stocks and it is first come, first served. Preorder today!
Lian-Li Lancool II ARGB Midi-Tower Case + Free HDD/SSD Hot Swap Back Panel @ £82.99 inc VAT
Free LAN2-3X Hotswap Panel with Lancool II Black preorders - Limited Stocks only!
Only £82.99 inc VAT.
ORDER NOW
Lian-Li Lancool II ARGB Midi-Tower Case - Black @ £82.99 inc VAT
Premium Midi-Tower case from Lian-Li in Black, Up to E-ATX motherboards, Mesh front and digital RGB-LED lighting, Tempered glass side panels, Three 120 mm fans pre-installed / up to eight supported
ORDER NOW
Lian-Li Lancool II ARGB Midi-Tower Case - White @ £87.95 inc VAT
Premium Midi-Tower case from Lian Li in white, Up to E-ATX Motherboards, Mesh front and digital RGB-LED lighting, Tempered glass side panels, Three 120 mm fans pre-installed / up to eight supported.
Only £87.95 inc VAT.
ORDER NOW
Lian-Li Lancool II Vertical GPU Kit @ £44.99 inc VAT
Conversion kit for the Lian Li LANCOOL II Midi-Tower, Riser cable including PCI slot bracket, For vertical installation of the graphics card
Only £44.99 inc VAT.
ORDER NOW
Lian-Li Lancool II Side ARGB LED Strip @ £13.99 inc VAT
ARGB-LED strips for the Lian Li LANCOOOL II case, 37 RGB-LEDs, Illuminates the case interior from both sides, Two mounting options
Only £13.99 inc VAT.
ORDER NOW
Lian-Li Lancool II HDD/SSD Hot Swap Back Panel @ £17.99 inc VAT
3x Hot-swap slot upgrade back panel, Designed for Lian Li LANCOOL II, 2x SATA power connectors
Only £17.99 inc VAT.
ORDER NOW
Lian-Li Lancool II USB3.1 Type-C Cable @ £11.99 inc VAT
Upgrade to the I/O panel of the Lian Li LANCOOL II, USB 3.1 Type-C port, Connected via USB 3.1 motherboard connector, 600 mm long cable
Only £11.99 inc VAT.
ORDER NOW
I like this case, and the front panel design, not a fan of the glass fronts on other cases. Not sure of the point of the hot swap panel thingy.. just makes a bit easier to upgrade add drives.
