Lian-Li LANCOOL II Mesh RGB or Corsair iCUE 4000X
The Corsair. Reason why is if you want to add more RGB hardware such as RAM, case strips & more fans, Corsair has you covered. The Icue software can be a pain to get it to go the way you like & it gets updates all the times because its so buggy, when it works it does work quite well.
No idea. Cooling a PC inside a case is all about how good the airflow is. That is important as in an ideal world you want as almost much cool air going in as you want hot air going out of said case. You'll want a balance between airflow & noise otherwise your PC will sound like a JET engine & could end up sucking in all the dust in the room where said PC is sited. Heat, moisture & dust is a PC's worst enemy. Corsair is one of the best around for PC cases & has been for over 10-15 years now.
Lancool 2 Mesh is a fantastic case, extremely easy to build in with fantastic accessibility and the airflow is second to none.
One of the best cases of the past few years regarding PC temps and the build quality is excellent, especially for the price.
