Lian Li lian pc7 plus question
28 Oct 2005
I am looking for a new case for a new build and the Lian Li pc7 plus looks to be a good choice. I was wondering what it is like to build in as it does not have a removable mobo tray. I had an Akasa 62/Mirage also on my list but paying so much more for (slightly as I read it) better cooling and a tray seems a bit bonkers.
I appreciated the pictures and reviews of this case that Yewen and others have posted.
Just leaving the question of whether its easy to move around inside it and get everything fitted etc (well as easy as it can be).
Thanks.
In the rig pictures I posted of the case with the window, there was room for both mine and mekrels hands inside the case at the same time, perfectly fine and plenty of room. :)
The motherboard tray is nice, but not a must really. Can be very handy but the PC7+ is not much more of an inconvience.
Just remember to put the PSU in first, makes your life a lot easier. :)
Qouted for the truth :)
I put my power supply in last, was a real nightmare, like Yewen says, put it in first :)
Most fit, but its just more screws to mess with so I never bother with it in the case, and just shove the PSU in first.
Its just experience with the case, makes sense if you plan ahead but you don't normally think to check these things with cases. :p
