Lian Li Mesh RGB case and M570 Tomahawk - Fan control?
7 Dec 2011
Hi all,
Ive built a PC with the Lian li Mesh 2 RGB case and the M570 Tomahawk.
Arctic AIO cooler with 3 fans
P14 PWM PST Fan 140mm x2
120mm, Black/Grey, Arctic Bionix P120 PWM PST x3
Im now trying to decide on fans.
My plan is to use the 3 arctic AIO fans on the front pulling in . Two 120mm fans on the bottom pulling in, and 2 140mm fans on top exhausting with one 120mm fan on the back exhausting.
Question is how to connect them all, as the case doesnt come with a seperate fan controller? The AIO fans have one connection which I think leaves 4 fan connections on the mobo which is one less than I need.
What would people recommend/suggest to control the 5 fans.
I went for a pwm compatible fan controller in the end.
3 of the fans onto the mobo and the 2 remaining via the controller.
Does the job.
I'd recommend the Arctic Cooling fan hub - it's A 10 port PWM hub that can be picked up for under £20
EDIT: Sorry didn't realise you'd already sorted
