Lian Li Mobo Question
You should have had copper coloured risers supplied with it.
You get a hexagonal screw driver to insert them too. Just be very careful not to thread them as the aluminium's very soft.
gt
Hornchurch said:
Ah kk thanks, am i meant to have enough screws to fill every hole, because i only have enough to fill about 3/4 of them.
Your motherboard will only have holes that line up with some of the holes in the case.
The case has lots so it can accept all types of motherboards.
I'd say you'd only need around 10 but check your board to see.
Just take it slow and make sure every hole on your motherboard has a corresponding riser attatched to the case in the right place. :)
gt
