- 13 Dec 2018
Hi Guys, looking for advice on parts for a new loop. I'm a complete noob when comes to watercooling and was looking for advice on the quality of parts. I've been advised on another thread that EK have been going downhill and thought to look elsewhere. Here are the components:
Case Lian-Li O11 D-Mini
GPU 3080ti FE
CPU TBA - i7 12th Gen
Mobo TBA - X570 AORUS MASTER
RAM HyperX Predator 4x4GB 3200Mhz
PSU EVGA SuperNOVA 850 P2
Fans Noctua NF-A14 140mm, Noctua NF-F12 120mm
Top Rad AlphaCool NEXXXOS ST25 FULL COPPER 360MM
Side Rad NEXXXOS XT45
Bottom Rad AlphaCool NEXXXOS ST25 FULL COPPER 360MM
Pump Alphacool 13320 Eisdecke
Reservoir PREMIUM CUBOID RESERVOIR 150
Fittings Bitspower TOUCHAQUA
Tubing TBA
CPU Block WATERCOOL HEATKILLER IV PRO
GPU Block WATERCOOL HEATKILLER V Nickel Black
Additional: Drain valve, angled fittings, temp & flow sensor
The theme of the build is chrome. Was hoping to get brass tubing, but don't think will have access to necessary tools to work with it. So the next best thing will be clear tubing. Would appreciate any advice.
GPU 3080ti FE
Tubing TBA
