Lian Li O11 XL ARGB Connector
18 Apr 2018
The front RGB strip of the O11 XL uses the following connector to plug into the inbuilt controller, and I'm having trouble finding out what sort of connector it is. There's a second plug available on the controller and I'd either like to utilise that, or alternatively find an adapter to plug this directly into the motherboard without requiring the built in controller. There's a pic below.
I have a Phanteks DRGB controller on hand and the the Lian Li plug looks similar but is a lot smaller.
Anyone got any ideas?
i might be wrong but it will probably only go into the rgb controller unit, looks similar to the ones used on all rgb controller that i have used. i've never put one anywhere else other than the controller provided.
on a side note, is it a nice case to build in, looking for a new build myself.
I used a argb male 3 pin converter to connect the case rbg hub to a commander pro, found on everyone’s favourite auction site, this was after I bought a JST to Corsair cable mistakenly
from the pic it looks like jst connector I got originally
This. Would be easier to find a connector from standard ARGB to any other proprietary connector than from a proprietary to proprietary.
