**LIAN-LI O11D EVO AVAILABLE FOR PRE-ORDER**
OcUK Staff
1 Apr 2014
OcUK HQ
Available for pre-order now, the Lian-Li O11D EVO. The evolution continues, with the Lian Li O11D EVO PC Case. Taking modular to the next level, this mid-tower chassis can be configured to one of two modes – Normal or Reverse. On top of this, there are multiple positions for I/O panel to be placed, and three orientations for your GPU. Choose from horizontal, vertical, or even upright to fully show off your gaming hardware. Thanks to the mesh panels and spacious interior, airflow has been maximised to the extreme and there is ample support for either AiO or custom water cooling. Plus, with its intelligent dual-chamber design, cable management is easy and the interior will stay looking sleek.
Lian-Li O11DEX @ £124.99 inc VAT
Only £124.99 inc VAT.
ORDER NOW
Lian-Li O11DEW @ £132.95 inc VAT
Only £132.95 inc VAT.
ORDER NOW
Lian-Li O11DEG @ £149.99 inc VAT
Only £149.99 inc VAT.
ORDER NOW
You can find all the amazing accessories for these cases here!: https://www.overclockers.co.uk/case...cessories/lian-li-accessories?sPage=1&sSort=1
A really exciting case with so many possibilities! Seems they missed a trick not enabling a 90 degree rotated configuration though. With the smart way the 180 degree configuration is enabled it wouldn't have taken much for yet another possibility to be unlocked.
Colour me interested, finally a new case without a restrictive 2 x 3.5 HDD limitation.
Why the difference in price?
I had a quick look but couldn't see any difference apart from colour.
I'm on about the cases in this thread.
The DEX is £125 while the DEG is £150.
An admittedly quick look at the two and apart from colour, I can't see any difference.
Maybe I'm missing something.
Black and White are on a preorder special price, Grey isn't. I believe standard prices will be £139.99 on the Black and £149.99 on the White.
Cheers, any idea how long the black will be on offer?
Just bought parts for a new system from you (not delivered yet) and was thinking of getting a new case as well, for the USB 3 support.
Hard to say, but I think it should last until early January at least.
Mine is ordered in Black with the Mesh and vertical GPU mount.
The plan is to rehouse 3x 120mm rads, 1x 120mm rad. Slight mod to fit a 200mm front fan with the 10x 120mm fans. All Noctua, love or hate them lol!?
Got this on Pre-order. Cant Wait to the New EkWB Radiators and fittings etc hit the shelves end of Feb to start the Watercooed build. Hoping they get a revised Matrix7 compatible distro out for the case asap
Updates:
Black and white cases are now £139.99.
I asked for an ETA on the extra parts I ordered, Black GPU mount, black mesh kit.
Oliver got back to me and quoted the following:
"The purchasing team have advised that the additional parts for the Lian-Li EVO case will sadly not be arriving at the same time as the case and are due to arrive early to mid February"
Updates:
Could have sworn the white was 132.99 earlier today
