- 23 Apr 2007
- Cardiff-ish, Wales
Hello all,
I'm looking for some advice on fan flow in a Lian Li O11D style case. I'm struggling to add an image, url below.
It would be easier if you could see the image! Anyway... EDIT - sorted the image
I'm thinking of 3 fans at the bottom drawing air in, 1 rear, pulling air out of the case, AIO at the top pulling air out of the case adn 3 fans on the side pulling air into the case.
I'm thinking of the following:
3 fans at bottom
www.overclockers.co.uk
1 Rear - do I need a reverable one here? I'm assuming that reversable simply means that the badge shows rather than just turning a normal fan around?
AIO at top - no need for LED displays on fans as the surface will be out of view. I'll just use the display on the block.
3 fans at side - I like the idea of showing temps on these in a visible part of the case.
Does this sound right?
Cheers,
Jed
3 fans at bottom
Lian Li ST120 Addressable RGB 120mm Black Fan with Controller - Triple Pack
Order Lian Li ST120 Addressable RGB 120mm Black Fan with Controller - Triple Pack now online and benefit from fast delivery.
Lian-Li UNI SL120 V2 Reverse Blade Addressable RGB Black 120mm Fan
Cool your PC in style with the Lian Li UNI SL V2 Reversed Blade fans, boasting significant improvements to both the performance and aesthetics.
Lian Li HydroShift LCD 360R AIO CPU Cooler 360mm - Black
With a Lian Li HydroShift 360R AIO, you can build a super-clean gaming PC with outstanding cooling, thanks to an innovative pipe routing design.
Lian Li UNI FAN TL LCD 120mm PWM, RGB Triple Fan Pack - Black
Add cooling and a distinct aesthetic to your PC with the Lian Li UNI FAN TL LCD Series, a high-performance fan with a fully customisable LCD screen.
Cheers,
Jed
