The default version of this case comes with a mesh of holes for the top panel of the case. Is there a kit I can buy to instead install a solid top panel in there?
Don't think so. Best you can do is cut to size some colour-matching plexiglass and try to sandwich it between the top fan/radiator bracket and the top panel. Not ideal, but the least intrusive approach.
