Lian Li O11D EVO Mid-Tower Case - SSD wiring?
30 Nov 2010
Northampton
I'm generally happy with my purchase of this case with one exception: I want to mount my 4 SSDs along the bottom of the case. You're meant to be able to with the bracket but then the SSDs are flush to the bottom of the case and very close to the side. It's basically impossible to connect the power cables to the SSDs as there's no vertical clearance. Why did Lian Li design it like this? SSDs are meant to be stacked. They should've provided a bracket that connected to the base of the case and just provided a stack of maybe 6 compartments one above the other where you could mount SSDs, like every other case does!
