Hi,
I need a new case with more airflow and looking at the O11D XL. There appears to be no way to contact Lian Li unless you have a claim or are an influencer.
I am looking at compatibility with the side fans and SSD, could someone answer the following questions.
1) The website says that 280mm and 360mm radiators will fit, but I have a Arctic Freezer 240mm, it does look like it will fit but can anyone confirm
2) If I use the side mount it looks like the additional SSD slots wont be able to be used is this correct ?
Thanks
Thanks
