Im just looking at cases and i cant really see a case i like that doesnt cost at least £200. I quite like the P50B and i see that it has 2 fans at the top of the case are 140mm.
Do you think if i got 2x 140 to 120mm adapters i would be able to fit a Coolit Eco 240 using the 140mm fans that come with the case with the 2x adapters and 2x 120mm fans doing push pull?
With the adapters, radiator and fans it would be about 65-70mm thick from top of case to bottom of 120mm fan?
