Lian Li PC-011 Dynamic Razer - Which fans?
15 Jul 2020
Hi! Just got this case (to be fair I didn't understand yet if it is a Mid or Full tower because I have seen both online but I think it is the same case..)
Nevertheless, I have seen that this comes with Razer Chroma.
The CPU cooler will be a Corsair H115i Platinum but for the rest of the fans in the case, I'm not sure which fans to put in there (the choices are not many where I'm getting this, Corsair/Coolermaster Sickleflow).
I am a complete newbie to this so I'm not comfortable chasing the fans myself but it is something I may consider afterwards if I find fans more suitable.
I can get Corsair 5 LL + controller but I guess these can't be controlled with Chroma. Could you let me know which fans I should be considering instead?
I wasn't sure in which section of the forum I should be putting this, I'm sorry if it is in the wrong one.
Thanks in advance.
Apparently there are 25 brands whose RGB products are compatible with Razer Chroma.
Still not certain whether any fans are confirmed as compatible though.
However, AFAIK, Chroma is just control software. Corsair has their own RGB control software, called iCUE, so if you were using that I expect it would happily control any RGB Corsair fans and any RGB you have on the H115i itself.
I also have the O11D Razer Edition. It's a great case! If you're not looking to spend an arm and a leg on fans I'd recommend the Coolermaster MF120 Halos as they are £39.95 for a pack of three plus a controller (if you don't have a mobo with any argb headers) from overclockers.co.uk. I have 9 of them sitting in my case and they work great, quiet too! I use razer synapse to control the case lights and then MSI Mystic light (or whatever mobo light control you have) to control the fans. I find they look really cool! Also Coolermaster has their own software where you can customize each LED in the fan but they haven't updated it to support the MF120s yet. Also you can daisy chain these fans so you only need 1 argb header and each pack of three comes with a 3 to 1 pwm splitter so in total you need 1 argb header (or rgb if you're going to use the controller) and 3 PWM slots.
