Lian-Li PC-60 PLUS/Lian-Li PC-7 PLUS???
The PC-7 is the best out of the two. Its cheaper as OCUK have a great deal on them. It should be much more expensive so is really a good deal.
They are different cases, but both share a similar chassis.
The PC-60 has a removable motherboard tray with a single 80mm fan in the rear. The plus edition has a 120mm fan at the front, I believe both have an 80mm blowhole.
The PC-60 comes with a larger, more solid hard-drive rack compared to the PC-7.
The PC-7 is essentially a budget PC-60.
Ages ago, socket A era then PC60 was the better case, but through the motherboard tray limiting the fan size, in the current PC market the 120mm rear fan and much lower price of the PC7+II makes it a much more attractive purchase.
