Hi,
Does anyone have the Lian Li PC-6B? Link: http://www.overclockers.co.uk/showproduct.php?prodid=CA-268-LL
It looks a great case; spacious, simple design, good quality and pretty cheap.
If you have it, could you post some images of it?
Also, can the hard drive cage be moved up, so it's underneath the DVD drive cage instead of blocking the fan?
Thanks.
Thanks.
