lian li pc-7+ fan replacements
Permabanned
10 Jun 2005
as it says in title i need new fans (2x120mm and 1x80m) to replace my stock fans would liek them to be as powerful but quiet as possible. can i attach a 120mm fan to the side panel grill? and how?
that talk isnt allowed on here.
I've just seen a lot of case fans, and ambers are poor for the prices that are charged for them.
the new scythe fans are also pretty good. no point in saying nexus as they are yates anyway.
The silentx specs are so far out its crazy so no point in recommending them.
I can only say what i believe :)
seriously can someone just tell me like the best makes without arguing lol
i have heard good things about scythe but they are pretty pricey anything better cheaper? if not i will go for them
cheers
Well as i said my choice would be ambers as thats all i've really heard as being good - and they are better than any stock fans i've ever had.
But Yate loons are getting more of a mention recently ;)
maybe you could use the search and see what comes up for ambers and yate loon, silenx etc.
yewens take on the matter
Having used the ADDA, Yates and Ambers I would put them in this order for noise.
12v:
Yates
Ambers
ADDA
7v:
Yates / Ambers (nout in it but the Yates appear to push more air, although not enough to lower temps)
ADDA
5v
Ambers
ADDA
Yates with a high pitched whine
ADDA's will be the stock Lian Li fans.
cheers
Have a look for Sharkoon 120mm 1000 fans or Aerocool Turbine 1000
Lol,
Yate Loon's at 5V is about as silent as your going to get while pushing some air.
In that table yewen posted the Yate Loon will win in all situations.
