Lian Li PC-7 Thermal/Air FLow Diagram
20 Jul 2006
OK what do you think? I will prolly order this case within the next month with the Blower fan and Scythe Kama Fan, this is how I think the air/heat will flow through the case, oh Blue Arrow means cold air and Red Arrow means Hot Air, pretty Logical Huh?...
Way to overcomplicated.
Ditch the blower fan and the top 120mm, and run it like everyone else, who all get good temperatures with that.
The purple you should use, the green is optional. That is the normal fan loudout for the PC7+, and usually offers the best temperatures when using Akasa Amber fans for the best bang for buck.
