what about "Also from a review, the case power button uses a 3 pin, but a evga 680i has a 2pin. How do i fix this problem?"BFG_9000 said:Yes...![]()
manoz said:If it's anything like my akasa eclipse which has a three pin power thing where only two of them are actually used then you will have to cut off the pin which hasn't got a wire going to it. Bit of modding needed unfortuantely.
flunky404 said:Hi
I had to do the same to my case.The power led is 3 pin but the middle hole is empty.I just took a junior hacksaw holding the connector with a pair of pliers and cut down through the middle hole being careful so you are left with the 2 pins.You could use a stanley knife to do the same.Job done![]()
Thanks for this.SpudMaster said:have you actually tried to fit 2 8800gtx's in a pc7 with the hdd cage still in place?
I got a x1900xtx in mine, for one card there is plenty of room but im not sure if a 2 8800gtx's would fit if 3 hdds were in the cage. It would be close with 2 x1900xtx's and 8800gtx's are about an inche longer
