Lian Li PC-7B Vibration
Caporegime
18 Oct 2002
Lake District
I've added a third hard drive to the bottom HDD enclosure and now I can hear/feel vibration through the floor near the pc. Is the bottom enclosure removable so that I could install rubber washers to reduce the vibration, or is there a better solution?
I'd rather not go down the bungee cord route as the hard drives then cannot use the case as a heatsink.
The bottom hdd enclosure is removable, so you could easily install rubber washers under the feet. You could replace the screws holding the hds in with those rubber anti vibration screw things as well?
What are those anti vibration screws I've never heard of them.
Ah, sorry mate. Just been to look and I was thinking of the ones you could get for fans. You could maybe put rubber washers between the hd and the enclosure though. The 5.25>3.5 converter I've got has these as standard and they do cut down on noise.
